A little prob.
hyck
Mazda 3i
A month ago I hit 50k and waranty is out :(. Now for the past few days, when I start the car, and start pulling it out of the parking its making some noise as if you are opening an old door, especialy when I turn the wheel, and that only happens for the first 30 sec of the car moving (confused). Any thoughts, or has this happend to anyone else? Thanks in advance.
I've had this problem constantly, brought it to mazda, the analysis was that nothing was wrong. Is it when you apply the brake or just idle out. My dad said it could be a warped rotor, bad brake lines, a ping in my springs, etc. I'm not too worried about it, if something fails mine is still under warranty.
sounds like his is more related to his steering if it is more appearant and louder with the turning of the wheel, could be a bad bearing in the pump or pulley?
none of my buisness but why do you run 17" with some 205/40 profile tires?
thats over reving the engine man, and you dont get the right speed, miles, ext...
I haven't noticed much of a difference, I broke the car in on those tires, it's what it's used to. It came with hubcaps and the day i got the car i threw them out and put the new rim and tires on.
