A couple of questions on aftermarket suspension
JBH_MSP
2003 Mazdaspeed Protege
First off, does anyone have suggestions for a good replacement for the stock shocks?
Also, has anyone used yellow speed coilovers? I'm having a hard time finding any feedback on them.
If you want a full coilover setup the Yellowspeed are the cheapest I know of. The megan racing are around $800 and I will probably get K-sports due to the rear camber plate. BC are one of the best if you can afford them.
I bought the tokico illumination kit (springs and struts) and have been very happy with them. I may be wrong, but I don't think you can replace the rear struts with anything other than oe because of the higher spring perch. If you go aftermarket, you will need new springs for the rear at a minimum.
