A/C turns off when the fan speed is set to 4.
deepdezal
Protege
Hello Guys,
I have searched the forum and I'm a bit confused as to what the issue is..
Is the fan switch gone bad or the fan resistor?
Thanks in advance!!
Deepdezal
Hello Guys,
Thanks in advance!!
Deepdezal
It's a well-documented problem. The cause is a burnt contact on the harness plugging into the HVAC unit. Remove the HVAC unit and look at the large (6 wire I believe) harness plugged into the back of it. Guarantee you'll find that it's burnt.
