KanseiZM said:Covered if you pay them![]()
cilyjr said:this thread inspired me to go in and look for myself....and ....I FIXED IT....i have a/c blasting on all four settings....hurray!!!
Maxx Mazda said:Care to share HOW you fixed it?
cilyjr said:not sure really i agree with mp3wannabe in that it must have something to do with the black ground, like it's not grounding well or something.
i disassembled the dash piece holding the control unit completely removed the control unit. than took the face plate off that( poped off both defrost button and a/c blew some canned air in there to get the dust off all the connections. i put the control unit back together and cleaned the connectors in the rear (where the wire harness plugs in). also there was a little black clip that was loose there the cable for the fan control was so i poped that back on(i don't think this was part of the prob as it was intact just loose). and when i tested it viola it worked. if all are curious on how to get it all apart i will try to make a how to tomarrow (i am at work now) but let me know i would be happy to do it but i don't want to waste my time though if noone is interested!!!
Dexter said:Those of you who want a (possible) cheap solution, help me out; I'm pretty sure I figured out how to fix my situation, but I need to collect some data from other people who are still using all stock components.
If someone could, I need voltage readouts from Contact D on the HVAC connector harness. It is a BLUE/YELLOW wire.
Please measure the following with CAR RUNNING:
Fan Switch OFF
Position 1
Position 2
Position 3
Position 4
Please post your results here, or better yet, PM me.
Thanks.
cilyjr said:mine started doing it again a week ago. i was told it should be the fan resisitor it is a part for 26 dollars online (not the control unit $180). i have ordered it and should arrive tomorrow or thurs (says ups). it is an easy install and when i am done and if it works i will post links to buy the part and a how to...but only if it works!!!
Maxx Mazda said:I just took my unit outand put it back in and it fixed the problem...
cilyjr said:so i just ordered the part from ken at protege garage his is the cheapest by about 10 and the shipping is included. for 180 all my ac needs will be fulfilled....i hope!
