R Rd02sir Member : 99 protege Nov 23, 2013 #1 My 99 1.6 pro isn't starting. I can bump start it, and it runs just fine, with no battery light, but I can't turn key to turn on. I do't hear a clicking like the solenoid is working. Where is the solenoid located? The starter is really hard to get access to. Thanks!
concept : San Diego, CA : 2014 Mazda3 S GT auto, 2008 MX5 6-speed Nov 24, 2013 #2 Have you had your battery load-tested? If not, that's where I'd start. Any auto parts store can do it, typically without charging you a dime. Most solenoids are attached to the starter, but it may be that your battery is too weak to supply sufficient current to turn the engine.
