Jasonjames
- Mazda 2002 BJ Astina 323 1.8 L
Are you sure about that? Try gooogling burn times vs octane
JJ
JJ
Let's just say the a higher octane resists compression more correct?
If it takes longer to compress doesn't that mean its burning slower?
Which in turn would increase gas mileage.
Maybe only a mpg our so but it helps.
A far as burning hotter or cooler,
If its only compressing when lit versus exploding from compression it is a more controlled burn and is causing less damage whether hotter or cooler.
I run nothing but 93 in my car and I only go to one gas company to try to keep it regular.
Race fuel will increase the these results only by the amount of octane increased effectually the difference of 87-93 is the 93-race fuel.
Octane boosters are not guaranteed the results listed on the bottle and should not be relied on.
End of rant
That post by me wasn't laid-out very well,.. It was me replying to the previous poster's statements. I should have annotated my responses. To keep it brief, lower octane fuels work best in lower-compression motors because LO fuel is more volatile. This volatility also means it burns faster, which is why its ignition timing is later [retarded] than higher octane fuel. Some folks dont get the fact that higher octane is slower burning. In addition, higher octane fuel needs to be ignited [by spark] earlier than lower octane fuels, because it takes longer to reach full cylinder pressure.
JJ
um... no.
