6speed manual reverse lockout broken
JMJinNC
2012 Mazda5 Sport 6-speed
Our 2012 Mazda 5 Sport. The reverse lockout mechanism is broken. It's a plastic part at the bottom of the shift lever. Anyone ever replace the shift lever and/or mechanism?
60k & out of warranty.
Thanks JMJ
Okay... so can anyone recommend a reliable used parts supplier for Mazda parts?
Thanks - JMJ
I have been trying to find the parts online for a few days now. That actual parts diagram for a 2012 is surprisingly hard to find. If it were me I would remove the busted stuff and take it to a local dealer and get them to find the part numbers for me. Then take those part numbers to a parts house of your choice (I like onlinemazdaparts.com) Given that yours has broken, I would be loathe to trust USED parts in this application, my 2 cents
PN found
The whole assembly is CD8746100A. Jim Ellis Mazda has them. If I found a used on I'd fabricate a new metal replacement of the broken part. Maybe even add a grease fitting on the sliding shaft.
JMJ
The issue is I can only get the whole assembly. Only one part is broken though, but the whole assembly has to come out to fix it. I'd rather get a cheaper used replacement and replace/reinforce the failed part at the bottom of the stick shift without losing use of the car for many days.
JMJ
It might be worth looking here and giving them a call. They're usually pretty good about finding the parts, and they might have it so you don't have to purchase the whole assembly.
update - I had the shifter mechanism replaced with a new assembly from MazdaSwag. They had the best price when shipping is taken into account.
JMJ
I know this is an old thread but I bumped into it recently when this happened to mine, so figured I’d throw a reply here incase it helps, I ended up designing and 3D printing one because I couldn’t find any decent replacements. I can’t seem to upload the file here. But if anyone else responds to this and feels it would be helpful I’ll find a way to get it to them.
Cheers
Cheers
Thanks for the offer...What file type is it?
@Zorra it appears you're using the file type .3mf I've added it to the list, can you try attaching the file in a post to see if it works. Being able to share 3D Printing designs/files would be very cool!
I’m going to try this, thank you for sharing!!
