626 wont shift need help fast!!!!!!
bassin42
I just bought a 1997 mazda 626,automatic transmission, 4 cilinder, it has about 120,000 miles. When i turn it on it shifts perfect into all gears, then it will completely stop moving in any position including reverse, so i turn it off then back and on and it shifts perfectly, then after a while it will do the same thing, i dont know if its soemthing electrical or what, any help would be greatly apreciated.
As i have seen, the automatic transmissions are known to have problems in 626's (i have a 2001 626 and have trans issues of my own). Does it have overdrive? if it does, try turning it off and see if that helps at all. it looks like a doozy of a problem, you might want to try and get your money back from whoever you bought it from. sounds like you got shafted.
did turning the OD do anything ? i'd check the fluid first, you may be low on ATF. i had a similar problem before with my trans and it ended up needing to be replaced. check the fluid though before you do anything expensive.
