626 Rear Brake Calipers w/ PosiQuiet Pads - Upgrade for P5/MP3 owners!
Status
Not open for further replies.
KrayzieFox
01 MP3 Turbo
As most of you know, the MSP has bigger brakes than the other Proteges, but MSP brakes are rare and rather expensive so it's not a viable upgrade for most of us. However, the 00-02 626 uses the same size rotor as the MSP with almost the same brake pad surface area, which makes this a cheap OEM upgrade for non-MSP owners. I was gonna do this to my MP3 but changed my mind so my loss is your gain.
Calipers are in GREAT condition!! They were pulled off a 2002 V6 626 w/ 85K miles on it, and I also have the brackets that are needed to mount them up to a Protege. Unlike the MZ6 rear brake calipers, the 626 calipers are compatible with the Protege E-brake so it's a direct swap. I also have a set of Centric PositQuiet ceramic brake pads to go along with the calipers, they come shimmed and include all the additional hardware needed for a proper install. All you need are rear discs from a 626, MSP, or MZ6.. they're all the same.
1. 02 626 rear calipers w/ brackets - $45 each
2. Centric PosiQuiet ceramic brake pads - $20
3. All together - $100 + shipping
Would to prefer to sell as whole package.
1. 02 626 rear calipers w/ brackets - came off a junked 626 w/ 85K miles. I've removed the stock pads that can be seen here and cleaned the calipers with brake cleaner. Pistons move smooth as butter!
2. Centric PosiQuiet ceramic brake pads - shims are already installed and they come with clips
Status
