626 pistons in B2200?
Junk Tech
1989 Mazda B2200
It's commonly known the F2 engine was used not only in my B2200 pickup, but also in some Mazda 626, MX6, and Ford Probe cars. The trucks used the 8 valve head, and the cars used the 12 valve head.
From what I read the car head is open chamber, and the truck head is closed chamber. To keep the compression the same with open chamber the car piston reportedly has a shallower dish. This means the car piston installed in the truck engine would yield a higher compression ratio when used with the closed chamber head.
My question is this ... "Can I use 626 pistons in my B2200 without valve interference problems?"
If so, I'll order an engine overhaul kit for the 626 when I rebuild my truck engine.
I'll appreciate your input.
Junk Tech
