60,000 service recommendations for my Turbo MP3
BoostedMP3
#4 Laser Blue Mica MP3
I'm just over 60,000 miles now and was wondering what is the list of to do's once 60,000 is hit? I need to know what i need to start replacing. This is also a turboed car so i don't know if that makes a difference or not.
lets see...
oil + filter.
replace/clean airfilter
trans fluid replacement (if its never been done)
Timing belt check/replace (if youre going to be in there specifically to check the belt, its just worth your time/money to go ahead and replace it)
check/replace waterpump.
inspect belts/pulleys. Check battery voltage/do required maint (if your battery requires it).
what else...
rotate tires/check brakelife?
well, so far i did my oil change, changed over to redline synthetic tranny fluid last year, tires r fine, i have a k&N air filter that i cleaned and oiled last year. I guess only thing on that list is check the water pump and timing belt, along with changing my plugs right?
bradicus18 said:
and plug wires
clean EGR valve maybe
I knew I forgot something!!
bradicus is right... although I wouldnt bother with the EGR valve until you start having idle issues (easy enough to do, but too much of a hassle to check).
I would also recommend looking @ all the suspension bits... check bushings/lube as necessary
i've had idle issues but it might be the leak from the BOV, i need to add like 2 more washers it make it shut all of the way after blow off
