6-7psi wastegate actuator
Will be the same. I had on my other Turbo car an 18psi external and replaced it with a 12psi external off of a Supra aftermarket kit for a completely different Garret turbo. Works as intended. You could even try tightening the tensioner arm on the wastegate that can give up to 3 psi of adjustement.
