have you got a full kit to put in the air to water?
I made a an aluminium reservoir that opens with one large nut on top. I used to throw some ice in there when I went drag racing. The pump is mounted under the air filter on the right hand side of the car.
Heres a *kit* I could sell you: Intercooler+Water reservoir+Pump+All plumping+Electrical switch and wiring+2 Blue coupling and hardwear. (most of the hardwear is in s/s) 550$ + shipping
You need to install it in a way that the water flow is opposed to the air flow, thewater outlet on the intercooler must be higher than the inlet and the water must flow from the bottom of the water reservoir and reenter on the top.
When you fill the reservoir with ice, it last about 2 runs at the drag strip. (refillinf every run would be advisable)
To install it, you would need to disassemble your intake or cut it, drill small holes in your engin bay to mount the water pump, wire the switch to turn it on and off. (switch included) Everything else is bolt on. (drinks)
Yes, here are pics of the water reservoir:
I will include instructions for installing it if you like.
I could also include more intake couplings, elbows or piping, turbo etc if you need it.
