R Rickkory Member : Mazda CX-9 Oct 11, 2010 #1 Does anybody know if these tires will fit a 2009 CX-9 265-50-20 Thanks.
ceric : 2022 CX-5 Turbo Nov 10, 2010 #3 By estimate, the side wall is 1cm taller (50% of 265mm-245mm = 10mm = 1cm). The diameter should be about 2cm larger. The odometer would be off by a little. Other than that, I don't see any big problem.
