Sorry for the late clarification. I'm oversees on business...
I have 235/40/18s mounted on the recommended 18" x 7.5" x 48mm rims.
These do not rub under normal circumstances. They also do not look like they should ever rub. HOWEVER, if you have a couple of adults in the back and you hit a big bump, the rear tire can make contact at the 10:00 position of the inside fender. This is not speculation. It happened to me, bent the inside of the fender and also took a chunk out of a tire. I had it fixed for $100 by having the rear fenders rolled.
I dont see any way you would go 1/2" wider (i.e. 245s) without this same problem.
Sorry to be the bearer of bad news. I still think going with larger tires/rims is a great idea. Just gotta be a bit careful in the back...
