my sons 240 is running bad so he did the tune up, cap, rotor, wires, plugs, fuel filter. checked the timing, but couldn't disconnect the throttle sensor harness connector. is it that important? without the disconnect the timing looks good. the motor and shifter is shaking badly. no smoking, leaks, overheating, no oil in radiator i'm running out of ideas. anyone with ideas? thanks all.
