225/50 Tires on a Mazda5 GT?
Do you know if I could fit 225/50 R17 on my 2013 Mazda5 GT? The standard size is 205/50 R17. I'm looking for winter tires and for some reason 225/50 R17 are more available.
should be fine,
when browsing for tires, the manufacturer usually states the min - max allowable wheel width that the specific tire you're looking at will fit. just make sure that the wheel you are using falls within that range.
225/50-17 will be about an inch taller than the 205/50-17 tire. A 225/45-17 will be a closer diameter match the OEM size.
I ran 215/50-17 on our old Mazda5 with OEM wheels.
Also, for winter duty, if you go too wide, the car will float over the snow, instead of cutting through it.
That's the answer I was looking for!!! Thank you so much for the information - I'll look for a standard tire size then.
I don't think it's that simple.
You also get more tread blocks for grip.
And unless there's a large difference in sizes, the amount of pressure applied per sq in isn't going to vary meaningfully.
So don't worry about wider tires in the snow.
