2023 CX-5 Tweeter upgrade
So I bit the bullet.
I acquired 4 bose speakers of a 2019 CX5
2x Tweeters (A Pillar)
2x Front Door Speakers
2X Rear Door Speakers (From a different mazda)
Now, IM NOT an acoustician.
The OEM speakers in my car were good, clear, details were audible.
My issue with them was They didnt sound Full or Loud. Like there was something missing with audio.
I had to crank up the volume to 50 and up to feel the audio.
On a bass heavy track the entire door would vibrate and bass sounded boxy.
Bose
The sound is definitely louder. Hitting the volume to 40ish.. everything is more than audible.
It sounds fuller (hard to explain) but it sounds better.
Question is how much better?
I guess about 15-20% better than audio on oem speakers.
Why Bose and no other?
Some other options needed splicing of the wires for connection.
Bose-Mazda speakers were simply plug and play.
I spent 5 mins for A & B Pillar speaker replacement.
and approx 10-15 mins per door.
Would I recommend ?
No.
I spent around 400 USD (approx in the local currency here) for some used speakers.
After the swap the audio experience is much better but not what I Expected.
I know this is a old thread, but did you have to remove the c pillar panel to get the tweeters out ? I found some videos where the panel was removed and all they did was push them out from behind. To me it looks like they could be popped out from the front with a door panel tool at the 12 oclock position and pry forward. I couldnt see any clips that would have to be released from behind the c pillar panel. Can anyone confirm this ? Thanks in advance !
I can't specifically say for the CX-5, but the C panel speakers for the CX-9 (which are probably the same thing) mount from the rear. Only the speaker grille itself mounts from the front.
Bose
Would I recommend ?
No.
Just FYI,
in order to gain 100% effort, ensure you also upgrade/pair with the same BOSE DSP ....
If you are not sure about it, you can dig onto some youtube experts and they will explain why it matters.
By the way, I am with 2024 GX - Canada, yes it is weak but it is acceptable (4 speakers only)
