2022 CX-5 CE non Bose factory audio amplifier upgrade
Non Bose system. Looking to upgrade factory amp to something with some more power. Leaving factory door speakers for now, not adding a sub. Any recommendations? Sound quality? Can factory door speakers handle more power? Any advice would be great. 2022 CX-5
Can't go wrong with Rockford Fosgate, Kenwood, Alpine, or even Mmats. Also check out D'Amore Engineering. The D'Amore amps are straight up incredible at that price point. (Tony D'Amore was the lead engineer for Rockford back in the late 90's and early 00's).
Factory door speakers can handle more power, but not too much more. Just make sure you don't blast your volume. xD Your speakers will tell you as you approach those limits though. You'll hear static/distortion, etc. Regarding amp, can agree with theblooms. I'd just add in hi level input w/ auto on/off to make install easier and no need for remote wire.
I probably won't go past 50-75 watts per channel for those door speakers. 50 watts are plenty for factory paper speakers.
I just upgraded my door speakers in my 2021 CX-5. I was surprised just how flimsy the factory non-Bose speakers are.
The common design is to have less expensive, lower efficiency (say 86 to 89 dB/w/m) speakers that inherently have limited frequency response on both ends. Then, the head unit has built-in filters, especially for low bass, to protect the speakers. Expect the OEM speakers to be 86 to 88 dB/w/m. Mine were. The Blose door woofers are about 83 dB.
You will get more by installing larger, more efficient speakers. Just changing to 3 dB greater efficiency speakers is like doubling your amp power. +6 dB would be like going from 20 watts stock to 80 watts in a new amp. Your new speakers will tolerate much more power later, if you still need an amp.
Ultimately you may want to change the head unit of the non-blose system because of the filters mentioned.
There is very little music below the 41 Hz open E on a bass, unless you are into pipe organ. Even dub-step doesn't get below 50 or 55 Hz. The pro subs used to play it are commonly -10 dB at 30 Hz. So concentrate on getting flat response to about 40 Hz and don't worry about the rest.
I found a source for the connector with wires for the speaker outputs. Works for the non-bose, under passenger seat tiny amplifier.
If you need the speaker connector with wires! I found a few sources for the part:
TH16FW-NH to TH16MF-NH Male to Female extension type (wire in between)
Aliexpress $7~ with shipping
The brand new original TH16FW-NH TH16MW-NH 16PIN is a connector plug for the navigation instrument host wiring harness of automo - AliExpress 34
Aliepxress both ends
Original TH24FW-NH TH24MW-NH automobile male and female 20cm harness connector plug - AliExpress
Walmart - $30 has the option of male or male and female - includes wires
The brand original TH16FW-NH TH16MW-NH 16PIN is a connector plug for the navigation instrument host wiring harness of automo - Walmart.com
This is a way better option than just getting the connector and trying to sort wires.
Just the connector - if you want that for some reason:
Home » Shop » Connectors / Harnesses » Sumitomo » 16 Way Sumitomo Unsealed Connector for GTR Steering Combination Switch
aliexpress.us/item/3256806320466008.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
UK website
6098-5279
Manufacturer website:
https://prd.sws.co.jp/components/series/pdf/en/nh.pdf
COnnector PDF
https://www.dalroad.com/wp-content/uploads/2015/06/NH-series.pdf
UK website
6098-5279
COnnector PDF
Oh man, I hope this works on my 21 CX-9 non Bose! If it does, you will absolutely RULE.
