2021 CX-5 Sport: How to add homelink?
<div class="bbWrapper">I recently bought this homelink since it was on sale. People say its compatible with almost all vehicles. Does anyone know if installing it will be easy. Can I draw power from my rain sensor/lane keep assist box on the windshield?<br /> <br /> <div class="bbCodeBlock bbCodeBlock--unfurl js-unfurl fauxBlockLink" data-unfurl="true" data-result-id="375612" data-url="https://www.tascaparts.com/oem-parts/kia-auto-dimming-mirror-with-homelink-and-compass-2t062adu01?c=Zz1lbGVjdHJvbmljcyZzPWF1dG8tZGltbWluZy1taXJyb3ImbD0xJm49QXNzZW1ibGllcyBQYWdlJmE9a2lhJm89b3B0aW1hJnk9MjAxNCZ0PWV4JmU9Mi00bC1sNC1nYXM%3D" data-host="www.tascaparts.com" data-pending="false"> <div class="contentRow"> <div class="contentRow-main"> <h3 class="contentRow-header js-unfurl-title"> <a href="https://www.tascaparts.com/oem-parts/kia-auto-dimming-mirror-with-homelink-and-compass-2t062adu01?c=Zz1lbGVjdHJvbmljcyZzPWF1dG8tZGltbWluZy1taXJyb3ImbD0xJm49QXNzZW1ibGllcyBQYWdlJmE9a2lhJm89b3B0aW1hJnk9MjAxNCZ0PWV4JmU9Mi00bC1sNC1nYXM%3D" class="link link--external fauxBlockLink-blockLink" target="_blank" rel="nofollow ugc noopener" data-proxy-href=""> 2011-2016 Kia Optima Auto Dimming Mirror with Homelink &amp; Compass 2T062-ADU01 | TascaParts.com </a> </h3> <div class="contentRow-snippet js-unfurl-desc">2011-2016 Kia Optima part # 2T062-ADU01 - Auto Dimming Mirror with Homelink &amp; Compass</div> <div class="contentRow-minor contentRow-minor--hideLinks"> <span class="js-unfurl-favicon"> <img src="/forum/proxy.php?image=https%3A%2F%2Fd354nuoz4t18d4.cloudfront.net%2Fd3675ed9c9ff716567f8c8a4a34f3bc2%2Fimages%2Fimage-favicon.ico&amp;hash=150821dac5e897f4e75799af5e84ff22&amp;return_error=1" loading="lazy" alt="www.tascaparts.com" class="bbCodeBlockUnfurl-icon" data-onerror="hide-parent"/> </span> www.tascaparts.com </div> </div> </div> </div></div>
<div class="bbWrapper">If yo can power it up and attach it, there&#039;s nothing special about a Homelink mirror other than it has the homelink remote built it. Kind of like taking your clicker and putting it in the mirror.<br /> <br /> I may be wrong, and my gf will probably tell you I am</div>
<div class="bbWrapper">To OP:<br /> There are three wires to a Homelink.<br /> 1. constant 12v - for garage door<br /> 2. switched 12v - for dimmer<br /> 3. ground<br /> I installed one myself few years back on a &#039;05 CX9.<br /> There are ground and constant wires in the doom light, but not switched 12v.<br /> <br /> What I did?<br /> I ran wires down the inside of A-pillar trim to the kick panel of your left foot (assuming LHD).<br /> There are contacts there. Switched and constant 12v. Ground is easy. Just tie it to a body panel somewhere free of paint or ground pin.<br /> A PDF instruction for Mazda accessory is here for the information you might need.<br /> <div> <a href="https://sep.yimg.com/ty/cdn/yhst-24809172479195/0000-8C-R06.pdf?t=1642015816&amp;" class="link link--external" target="_blank" rel="nofollow ugc noopener" data-proxy-href=""> https://sep.yimg.com/ty/cdn/yhst-24809172479195/0000-8C-R06.pdf?t=1642015816&amp; </a> </div></div>
<div class="bbWrapper"><blockquote data-attributes="member: 49495" data-quote="ceric" data-source="post: 6747028" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=6747028" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-6747028">ceric said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> To OP:<br /> There are three wires to a Homelink.<br /> 1. constant 12v - for garage door<br /> 2. switched 12v - for dimmer<br /> 3. ground<br /> I installed one myself few years back on a &#039;05 CX9.<br /> There are ground and constant wires in the doom light, but not switched 12v.<br /> <br /> What I did?<br /> I ran wires down the inside of A-pillar trim to the kick panel of your left foot (assuming LHD).<br /> There are contacts there. Switched and constant 12v. Ground is easy. Just tie it to a body panel somewhere free of paint or ground pin.<br /> A PDF instruction for Mazda accessory is here for the information you might need.<br /> <div> <a href="https://sep.yimg.com/ty/cdn/yhst-24809172479195/0000-8C-R06.pdf?t=1642015816&amp;" class="link link--external" target="_blank" rel="nofollow ugc noopener" data-proxy-href=""> https://sep.yimg.com/ty/cdn/yhst-24809172479195/0000-8C-R06.pdf?t=1642015816&amp; </a> </div> </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>This sounds a bit complicated. I have taken out the A pillar before while doing installing the dashcam (powered via the OB reader). <br /> <br /> Installing this homelink seems like a lot of work. You said doom light would be a no go for the homelink system. But would the rain sensor/lane keep assist box on the windshield have those three components (constant 12v, switched 12v, ground) for the homelink? I dont mind if the garage opener does not work when the car is turned off (will help as a security measure if the car is parked outside).<br /> <br /> Also I feel like I dont need the dimming feature? have never toggled the dimming version on my non powered rear view mirror on my SUV.</div>
<div class="bbWrapper">Rain sensor should be on switched 12v, but I am not sure if the current draw is sufficient. Your call. <br /> <br /> If you don&#039;t need the dimming, then, you can buy a basic Gentex mirror w/o auto dimming. In that case, you only need constant 12 (dome light) and ground (which also can be found inside dome light cover).</div>
<div class="bbWrapper">Hi, I have a problem connecting the mirror with the Homelink function. I don&#039;t like the color scheme of cables and positions in the manual and in reality. Now the auto-dimming feature works for me, but the Homelink doesn&#039;t. I have a European CX-5 2022. I have a wrong cable for Homelink, what should I connect it to?</div>
<div class="bbWrapper">try to find the instructions for the frameless mirror accessory. It shows where to splice in , because it is not plug and play also. somewhere in the A pillar if I recall.<br /> btw Does homelink even work in Europe (frequency wise)?<br /> <br /> the mirror as said above has 3 main wires.<br /> constant 12v+ used for homelink (its always on)<br /> switched 12v+ for autodimming<br /> and ground 12v-</div>
<div class="bbWrapper">yes, Homelink works, I just found out before buying the mirror, Homelink and garage door motor work on the same frequency.<br /> yes, I have it connected in the A-pillar, but according to the instructions, the position and color of the cable do not match reality, the given position according to the instructions is a different color in reality, e.g. in the instructions, there is a purple cable at the given position, but in reality I have pink, purple is in a different position</div>
<div class="bbWrapper">I cannot help in your particular case, but when we got our 2014, I added an eBay 2013 autodim/homelink mirror. I had assumed it would be plug and play, but found, like you, that wires were different. I was able to swap around pins in the mirror-side connector to match the car side one to get it working.</div>
