2016.5 CX-5 OBD2 pinout wiring diagram
CX5 Touring
2016.5
Does anyone have the ODB2 pinout wiring diagram for 2016.5 CX5? I'm trying to find which pin is the ACC pin.
Thank you.
ODB2 pinout is a standard for all current vehicles. If you don’t see the pin you need from ODB2 pinout wiring diagram available on the Internet, that signal doesn’t exist.
Some cars have a pin on the OBD-II port that is tied to ignition ACC power. Manufacturers can use pins 1, 3, 8, 9, 11, 12, and 13, for whatever they want so it's not a standard because some manufactures uses 8 for ACC while others don't.
