I am new on this forum, hoping to get some help. I have a 2015 cx5 having issue with long crank. The issue is intermittent. Once the car starts, there is no issue like stalling or misfire, fuel economy.
I’ve recently changed battery (energizer group 35, 640 CCA). Alternator also charges fine (tested with multimeter).
Sometimes, with long crank results check engine p0335 code (crankshaft positioning sensor code). I have also changed that sensor but no luck.
I am hoping to get some suggestion from this forum.
Thank you
Thank you
