2012+ wiring diagram alarm / remote start
chad99
2013 Mazda 5 Sport
Hey guys planning on installing a remote start pke alarm. Anyone know the wire colors and location for a 2013 sport
Thanks
Attached are the instructions for installing Mazda remote starter.
I can't imagine aftermarket will be much different, maybe a few wires, but will give you good idea.
Nice, thanks Vasy, now I just need to probe the ignition switch wires, simple enough.
They sure give you a ton of info, almost fool proof
Thanks again
Just putting this here for others:
DIRECTWIRE WIRING INFORMATION - MAZDA / MAZDA5 / 2013 / Remote Start
12volts blue/black (40A) + ignition switch, white 8 pin plug, pin 8
Starter blue/red + ignition switch, white 8 pin plug, pin 5
Ignition blue + ignition switch, white 8 pin plug, pin 1
Accessory black/red + ignition switch, white 8 pin plug, pin 6
Second Accessory black/white + ignition switch, white 8 pin plug, pin 7
Keysense blue + ignition switch, white 8 pin plug, pin 2
Power Lock blue -1000 ohms either kick or BCM behind glove box, white 24 pin plug (6), pin 14
Power Unlock (same as power lock) -
Lock Motor red/blue to red/yellow 5 wire either kick or BCM behind glove box, white 16 pin plug (5), pin 8
Unlock Motor red/black 5 wire either kick or BCM behind glove box, white 16 pin plug (5), pin 7
Parking Lights+ blue/black + passenger kick, harness to rear
Parking Lights- brown/red - headlight sw or BCM behind glove box, blue 24 pin plug (2), pin 23
Hazards blue/yellow - hazard sw or BCM behind glove box, blue 24 pin plug (2), pin 7
Turn Signal(L) black/red + pass kick or BCM behind glove box, white 16 pin plug (5), pin 3
Turn Signal(R) red/white + pass kick or BCM behind glove box, white 16 pin plug (5), pin 2
Reverse Light blue/white + pass kick or BCM behind glove box, gray 24 pin plug (1), pin 9
Door Trigger white/blue - N.C. either kick or BCM behind glove box, white 24 pin plug (6), pin 4
Dome Supervision yellow/black - pass kick or BCM behind glove box, white 16 pin plug (5), pin 15
Trunk/Hatch Pin red/black - pass kick or BCM behind glove box, white 24 pin plug (6), pin 15
Hood Pin gray - N.C. BCM behind glove box, gray 24 pin plug (1), pin 17
Trunk/Hatch Release purple/yellow (rear handle switch) - pass kick or BCM behind glove box, white 24 pin plug (6), pin 8
Factory Alarm Arm blue/orange (driver door key lock) - either kick or BCM behind glove box, white 24 pin plug (6), pin 2
Factory Alarm Disarm lt. green/red (driver door key unlock) - either kick or BCM behind glove box, white 24 pin plug (6), pin 13
Disarm No Unlock (transponder and ignition)
Tachometer black/white, black/yellow, black/blue, or blk/org ac any fuel injector, white 2 pin plug, pin 1
Brake Wire red/yellow + brake switch, white 4 pin plug, pin 4
Parking Brake brown - pass kick or BCM behind glove box, blue 24 pin plug (2), pin 9
Horn Trigger purple/white - horn switch or BCM behind glove box, blue 24 pin plug (2), pin 11
FYI anyone that is planning on installing an alarm, you have to use the door trigger mentioned in the Mazda remote start guide above posted by vasy, the one I listed from Directwire is only the drivers door trigger.
Thanks Vasy. This is awesome to have. Does your source have this for the previous gen?
DIRECTWIRE™ WIRING INFORMATION - MAZDA / MAZDA5 / 2013 / Remote Start
This is a great reference! Can you pull the same for the previous gen, say 2008 model? Thanks.
Battery BLACK & BLACK/YELLOW (+) IGNITION SHWITH HARNESS
Ignition 1 BLUE (+) IGNITION SWITCHHARNESS
Accessory 1 VIOLET (+) IGNITION SWITCH HARNESS
Accessory 2 BLACK/RED (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/BLUE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense WHITE/BLUE (-) IGNITION SWITCH HARNESS
Tachometer BLUE/BLACK (AC) AT PCM MODULE ON DRIVERS SIDE FIREWALL UNDER HOOD
Speed Sense GREEN (AC) AT PCM MODULE ON DRIVERS SIDE FIREWALL UNDER HOOD
Parking Lights GRAY/BLACK (+) BCM MODULE BEHIND GLOVEBOX
Low Crr. Pk Lights BROWN/RED (-) BCM MODULE BEHIND GLOVEBOX
Brake Lights GREEN/YELLOW (+) SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED/YELLOW (+) IN HARNESS IN PASSENGER KICKPANEL TO REAR
Horn VIOELT/WHITE (-) IN HARNESS AT STEERING COLUMN
CANbus RED & BLUE (DATA) DATA LINK CONNECTOR
Taken from here
http://www.the12volt.com/installbay/forum_posts.asp?TID=123459
