Went to change headlight bulb on my 2012 m2 touring, but found the set up different than what I found in the owners manual and online...
There is no connector plug between the bulb and the wiring. Wiring is attached directly to the bulb. There is nowhere to simply unplug the bulb from the car. Can't replace bulb. Any help or suggestions?
Thanks in advance
Thanks in advance
