Lost interest, rode it for about 50 miles with the swap. Lots done, still needs some tuning done, running rich. Asking $3500.
NCY Variator(115mm)
Ballistic Evo 2 8-Cell Battery
GY6 2mm Stroker Crank
Taida Starter Motor
Dr. Pulley Sliders 12.5g
Mainfold intake riser 31mm
Rattler Exhaust Pipe
Short Axle
Throttle Cable Size 75"
Rear Drum Brake Cable 84.3"
ANGLED Clocking Flange
Mikuni Fuel Pump Bracket
Carburetor 24mm
Fanfare 12x7 Wheel
150cc GY6 Motor Engine -
MIKUNI Fuel Pump
NCY Low Boy Shock -
Mojo Mount Fatty 7"
Makoa Scooters Plug-n-Play Harness
11 Pole Stator Kit - Includes Flywheel and Rectifier
Starter Relay (Small Blue Box on Batt Fuse Block)
HOCA CAM A12
Gates Premium Belt
NCY Big Valve Cylinder Head 58.5mm
NCY Cylinder 58.5 mm
Taida Valve Cover + Gasket
Dr. Pulley Sliders 11g
TAIDA Starter Motor Clutch
OEM Starter Motor Clutch NUT
Clutch Bell Housing
NCY Handlebar Stand
NCY Spark Plug Coil
NGK Spark Plug Cap
PasswordJDM Rear Hub
NCY CDI Box
NCY Orange Fan
Handlebars
Small Profile Turn Signals
Mirrors
Foot Pegs
Kick Stand
Michelin 140/70-12 Rear Tire
Michelin 120/90-12 Front
Extra
GY6 150 Starter Relay/Solenoid
NCY Variator(115mm)
Taida Starter Motor
Short Axle
Carburetor 24mm
Fanfare 12x7 Wheel
MIKUNI Fuel Pump
NCY Low Boy Shock -
Mojo Mount Fatty 7"
HOCA CAM A12
Gates Premium Belt
Clutch Bell Housing
NCY Handlebar Stand
NCY Spark Plug Coil
NGK Spark Plug Cap
NCY CDI Box
NCY Orange Fan
Handlebars
Mirrors
Foot Pegs
Kick Stand
Extra
