2011 CX-9 AWD Front and Rear differential mount bushings (are they the same?)
Hello everyone,
I have a mazda CX-9 2011 AWD and will be replacing various bushings and mounts. I have done the 2 motor mounts and trans mount and will be taking care of the differential to rear subframe bushings (as they are totally gone).
However, I am having trouble finding the bushings for the front differential mount. I have found the bushing for the rear diff mount but cant find the front. I can only find the OEM mount which is 150$+. Is the bushing that goes in the rear diff mount the same as the one that goes in the front diff mount? I ask because when I searched up the front mount part number it showed me that that part number can be used for either the front or rear differential mounting.
Thank you
if you mean the front transfer case, it is bolted on the transmission, there is no bushing holding it in place.
New Threads
