Tried to change interior bulbs to LED myself and got the map and trunk lights done, but pushed the dome receptacle too hard trying to fit the bulb in that *really* tight spot. The receptacle was successfully pulled back down into place but now the switch won’t work properly (bulb stays on no matter where the switch is set, and the switch just slides right and left without clicking in place); presuming I undid some tab or connection in the dome assembly when I pushed it up *doh*
Is there a trick to getting the entire dome light assembly out of the headliner intact? Didn’t see front/back clips like the map light assembly had, nor right/left, but it’s attached up there somewhere pretty firmly.
Thanks in advance for any help
