2010 Mazda3 2.5L; ABS and Traction Control warning lights on. Help
I have a 2010 Mazda 3, 6-speed manual, 2.5 liter. The ABS, traction control and brake lights are all illuminating--C0002, C0082, C0020 and D0415. Trying to avoid an expensive repair--just wondering if this might be caused by a loose connection or a wire harness (friend's idea) that needs to be replaced or cleaned. Any ideas??
Did you get an answer for this? I have the same Mazda 3 2.5 hatchback with the same problem. Last time I researched they pointed that it could be a faulty ECU which at the time was $1,500 or so in the junkyard.
New Threads
