J jtech4 Member Dec 9, 2010 #1 Hello all, looking for some new rotors for my cx9, can someone tell me a good aftermarket site?
J jtech4 Member Dec 10, 2010 #3 The car is my work car and I drive alot NYC roads also am hearing squeaking sound on when braking.
ceric : 2022 CX-5 Turbo Dec 10, 2010 #4 Squeaking sound from CX9's brakes could be normal, especially so when the brake is cold. Mine does that all the time. After the brakes are warmed up, they should quiet down. If not, the pads are indeed worn down. Last edited: Dec 10, 2010
M mihalis Member Dec 27, 2010 #6 If you must change, I would recommend you go with Frozen Rotors... http://www.frozenrotors.com/ Good luck!
