2008 CX-7 Grand Touring 170k miles. Oil recommendations?
Hello to all from TN. Just picked up a second vehicle to go to local stores in. It is a 2008 CX7 Grand Touring with 170k on it. Got it from original owner and it was garage kept it's entire life. Of course it has the oil filter housing gasket leak which I am getting replaced. What 5W 30 oil do you suggest I go with at this point? Everything else is fine with the car.
Thanks in advance,
JJ and TJ from TN
I use what the owner's manual recommends on my '09 CX7, and I use synthetic oil simply because then I don't have to get the oil changed as often. Haven't had any problems by doing that regularly. Mine has about 93K miles on it.
