2007 manual, page 4-2
Your Mazda will perform best with fuel listed in the table.
Fuel Octane Rating*(Anti-knock index)
Premium unleaded fuel 91 [ (R+M)/2 method] or above (96 RON or above)
* U.S. federal law requires that octane ratings be posted on gasoline station pumps.
This vehicle is designed for and requires use of premium unleaded fuel. If 91 octane fuel [
(R+M)/2 method] (96RON) is not available, gasoline as low as 87 octane [ (R+M)/2
method] (91RON) can be used temporarily for emergency purposes. Use of gasoline lower
than 91 octane [ (R+M)/2 method] (96RON) can decrease performance and deteriorate shift
quality during its use. Refueling the vehicle with the correct octane fuel a couple of times
will restore vehicle performance and shift quality.
And the 2008 manual also page 4-2
Premium unleaded fuel 91 [ (R+M)/2 method] (96 RON) recommended
This vehicle is designed to use 91 [ (R+M)/2 method] (96RON) or higher gasoline for best
performance. If 91 [ (R+M)/2 method] (96RON) is not available, 87[ (R+M)/2 method]
(91RON) gasoline can be used. Use of gasoline lower than 91 [ (R+M)/2 method]
(96RON) can decrease performance, deteriorate shift quality and cause engine knocking
during its use.
