2006 Subaru Imprezza WRC2006
quagmire
Engine
Type: Flat-4, Turbocharged (IHI, with WRC regulation 34mm restrictor)
Displacement cu in (cc): 121 (1994)
Power bhp (kW) at RPM: 300(224) / 5500
Torque lb-ft (Nm) at RPM: 347(470) / 4000
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: AP Racing 305mm ventilated discs and 4-pot calipers front and Rear. For asphalt use, front brakes are 366mm ventilated discs with 6-pot water-cooled calipers
Tires F-R: n.a.
Driveline: All Wheel Drive
Exterior Dimensions & Weight
Length Width Height in: n.a.
Weight lb (kg): 2711 (1230)
This is sex.
HP isn't all that impressive...but 347 lb-ft. out of a 1.994L engine is damn incredible I must say with that 'restrictor' in place. 34mm is small.
Seems like really low ground clearance for a WRC car though...
