2004 SRT-4 stage 1 vs. Thumper MSP
Bryan, what happened to the computer you were running before? Didn't you have Haltech? Why did you get rid of it?
yes you could...
about the haltech, i unloaded it a while back because i couldnt get it to run right in the cold. Also, the stock msp ecu seemed to be fine, and it was up until 11 psi where the afrs were right at 12.0 .
i have since installed an extra injector setup, and have tuned the fuel for 13 psi-14 psi about. The maf sensor is maxxing out even with the fcd, so i think it is time for emanage and z32 maf..
-B
Our attitudes about this here are worse than the attitudes over on the SRT Forums... They are generally accepting of Brian's car, and the results of the race without putting us down.
Now that this is out of the way, I want to congratulate you on some sick runs man!
its the thumper kit, sort of a pre-release version.. some things have changed.
its a GT3037 turbo, so its not even breathing till 12 psi or so
ok thanks oh 1 more thing do i need 2 upgrade any internal for this kit if so wut iz needed so i can run safely like 14psi
Well you guys have used up all my bandwith for the month of May ;)
Those 3 vids alone accounted for 25 gigs of bandwith (my site has 40gb / month).
Haha.
dynoed the car today at 13 psi. 284.3 whp on a dynapak SAE corrected.
not bad hey?
-B
