2003 Protege 5 fuel line disconnect tool
Rick Dog
2003 Mazda Protege 5
I have to remove the fuel pump assembly once again because the metal pump unit cover seems to be warped, leading to seepage/leakage. How do I disconnect those fuel lines? I bought a cheapo fuel line tool from Advance Auto, but it was a b**** to work right, and I had to finagle some other L-shaped tools to disconnect those lines. What does a Mazda dealer use? What do you use?
I'm frustrated,
Rick
If you do not want to buy a special tool, you may use small flat screws. The following video is really informative to how to disconnect fuel supply lines ( It's in French but it's as clear as silent movies ) It's a PITA work and took me more than an hour not to mention how did I dealt with corroded screws. Mazda should have used better screws
http://www.youtube.com/watch?v=hgZ6PFO1TXg
This video is also great but I do not agree his suggestion to how to disconnect. All other items are helpful and deserve a great thank.
http://www.youtube.com/watch?v=TvGrtiKnckw
