2002 Protege5 transmission question
huettejo
2002 Mazda Protege5
I have a 2002 automatic protege5 and here recently it started to hesitate when going into drive. It shifts gears fine and the performance of the car has not changed. Is this something I should be worried about??
hows ur break pedal?
does it hesitate when u move the stick or when in drive already
It does it when I move the stick. Once in gear it is find! And it has been a while on the fluids. Would that cause it to do that?
auto or standard? n try not to move the stick if auto
and wear n tear would cause it, depending on ur mileage n maintenance
Maybe fluids. What's your mileage? I have the sportmatic auto in my 03 p5. If you change the fluid, change the filter as well. There is a write up somewhere
