I don't think bad valve stem seals or a bad PCV valve can cause a car to use a quart of oil in 20 miles in an otherwise healthy engine. I'm assuming you have looked for a big puddle of oil under the engine. Have you looked at the spark plugs? Compare them with the plugs in this link to determine their condition.
http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
Bad valve seals will not affect compression. Compression is checked within the combustion chamber when the valves close. The valve seals are outside the combustion chamber.
A leak down test only checks for leaks from the combustion chamber. By listening for escaping air it can tell you if the combustion chamber leaks through the intake, exhaust or crankcase. It does not indicate the condition of the valve stem seals.
Those checks are OK but you are going to have to at least remove the cylinder head to determine the cause of your heavy oil consumption. Be prepared to spend $$ for an engine rebuild or replacement.
Clifton
