- 2012 Touring MT
If you want 260+ hp sell the 2 and get a ms3.
It is that simple.
Agree
Andres
It is that simple.
It is that simple.
If someone was to swap in a 2.0 or a 2.3 might as well go big.
-Derrick
Yes but the difference in 180hp all motor and 180hp turbo is that the all motor (2.3l swap) is infinitely more reliable with less things to break or maintain than turboing the stock engine. AND you then have to worry about our transmission, 180hp input into our little transmission that can't will cause 2 problems. 1) The gearing SUCKS. It's means for city driving and fuel efficiency almost doubling the horsepower you can just skip 1st gear, and 5th gear is going to feel like driving everywhere in 3rd. 2) The internals will not be able to handle that amount of power for long.
you are running with lower compression ratio but with stock internals?
Hello there. Just to inform u i turbocharged my mazda 2 on the original 1.5 engine with some modifications to make the cylinders more durable under pressure , i am running a td04l turbo with 550 cc injectors and i am getting 250plus hp out of it . It is simply outstanding and still lightweight and easy to handle (eekdance)
Yep, thinking the same thing here, how is this possible? MZR 1,5l has 10:1 compression ratio oem....
With a thicker head gasket you can lower the cr without changing pistons or anything else.
Yeah man it is mazda internals
with a thicker head gasket you leave a weak point in the whole combination which would the gasket itself , now it has to withhandle the pressure and temperature of the combustion chamber , whereas in lower piston the gasket is 0.1mm which is nothing , but the pressure and temperature stays on the walls of cylinders and you have a more durable engine.With a thicker head gasket you can lower the cr without changing pistons or anything else.
Guys i am going to tell u my secret . I am using mazda3 1.6 pistons which are slightly concave and have shorter connecting rods. They fit perfectly and give a 3mm clearence from the face of the block cylinder to the face of the piston that way i used the oem gasket . And there you have it low compression and a very durable engine 1.2 bar boost and running like a dream
