1998 Mazda 626 transmission issue
I have a 98 mazda 626 with a 5 speed manual transmission. My problem is that the transmission is stuck in gear. I replaced the slave cylinder and now to clutch pedal functions. The shifter moves fine but the transmission wont come out of whatever gear it is stuck in. I popped the cover off for 5th 1st and reverse and when you shift the transmission to 5th 1st or reverse it looks like its engaging fine but its still stuck. Im almost wondering if theres something wrong with 2nd 3rd or 4th but i wont know unless i pull the transmission. Im trying to avoid that as much as possible but everything i have checked so far seems fine. Any idea what could be going on with it. The guy i bought it from said he was driving it then it just died going down the road and now its stuck in whatever gear he was in.
Thats kind of what i was assuming but i have no way of telling without pulling the trans. I figured either broken shift fork or broken roll pin.
