cheartburg
(uhm) I am a female(boobs2) and I bought this car as a lien sale. I haven't really had any major problems with it until about 3 weeks ago, when a piece of rubber at the end of throttle cable slipped down the cable & held throttle open @ around 7,000rpms. (noticed rising rpms @ 65 mph, could not down shift to resolve & I could not get off hiway for about 2 miles, to shut down. I was able to locate the problem fairly quickly, & then it started & ran fine. Now I was just cruising along @ 55mph & engine just went "quiet" & died. After about an hr, & a few things wiggled & tapped, it started up & I was able to drive the 2 miles back home. Then 2 days later, I started it again & was driving under same conditions, & it went "Puhh" and died again. (It was like a slight backfire) When key is turned on, it "wants" to start, but there is no noise from sending unit or fuel pump, until the key is OUT of the start position. It does not make any sounds before, like in the "on" position. I manually depressed the clutch switch & hit the key, and had also tapped on the fuel filter, & God knows what else I wiggled!(butt) but the underdash sending unit & fuel pump both started clikking, & I was able to start it, but both units kept making noises while the engine (briefly) ran, before dying again! They kept clikking when the key was turned on, but then reverted back to doing so, after the key was taken out of the start/on mode. Any suggestions? The fuel pump & pump sending unit are easily accessed, under the rear seat. If the engine has "died" in this way, has the fuel pressure been relieved? (I don't want to disconnect any fuel lines & have fuel spray all over the back seat.) I am curious to know if the "now" problem may have had to do with the high rpms caused by the previous incident. I love this little car, but this problem is causing difficulties, as I am trying to find work, & live in a remote area, & really need my car! Any feedback from you guys or girls out there would be appreciated! I also have worked on my vehicles before, so I'm not a total car dummy! I forgot to mention that this is a "California" car! (146,000+ miles, good timing belt, Full Tune-Up less than 4,000 miles ago; Plugs-Wires-Cap-Rotor all new.)
