There is a window on both ends of the carb where you can see how much fuel is in the bowl. There is a notch visible through the window, your fuel level should be within the notch. If not then yes, chances are you need to adjust your floats. You don't have to remove the whole carb to do it, you can just remove the top section and will have access to the floats. Another thing is if you replaced your float needles with Gros-Jets (not sure if they are even available any more) you will definitely have to make adjustments. Ask me how I know...The factory manual will have the settings for the floats, I'm about 6,000 miles away from mine at present or I'd look it up for you.
