freekwonder said:not all your fault I may have taken it wrong.
So whats a Be-cool rabbit Rad.w4e I may have to look into that. got to keep a 2.4l cool.
I may have to call Troy about that. I got my 280zx tokico struts and ground controls from him. but that should get me as low as I need to go since I plan to run 15s on the car. Cant go to low or I wont be able to turn, since I'm still torn if I want to do flares or not.
I'll have to keep that in mind about the r160. Since I'm half broke I figured I could kee the 160 until I broke it. I though the quiafe for the stock 160 was EXPENSIVE as hell.
What did you guys do to the subbie 160. I though you had to modify the stock axles to get them to work?
the Be-cool is a brand of alluminum Rad,you can get them through Jegs or Summintracing.
as for the R160,all you have to do is take of the subbie stub axles,and stick on the 510 ones,it takes about 2 minutes,and yes,the Quafie is DAMN expensive,but when it's in a R160 it will react/outperform,and take more abuse then a R200,and theres the fact that it literaly bolts in.
your best bet is to just get a R160 LSD from a subbie. price/performance/ease of install you really can't beat it.
