18 " Rims, offset and tire size recipe?
goin2mlb2
Anyone who has put on 18" rims let me in on the offset recipe? Also, what size tire are you running? Id like to go just a little taller than the stock wheel and tire setup to maybe fill the wheel well a little more,(not a fan of the lowered option), if its possible. Id also like a little wider rubber than the rubber bands im rolling on now. Also, where can I get these clear side markers I see on everyone's posted pictures? Thanks a lot.
Welcome to the boards, goin2mlb2. As for your question, are you saying you want 18" rims AND taller tires? If so, I don't think that's really gonna happen. If you MUST go 18", I'd go around 18x7.5 with a 225/45/18 tire at the ABSOLUTE largest.
Although, I'd strongly urge you to go with 17's over 18's. Why? 17's are lighter (helps acceleration), they are smaller, (helps acceleration), and cheaper (helps acceleratin because you'll have more money to put into the engine).
Oh, BTW..try to keep the offset between a 45 and a 55. Preferably closer to 55.
As for the clear sidemarkers, run a search.
