- 10 MS3
Will these fit on the 3 dropped with Pro-kit?
tsunami said:no... i have 7.5 wide with a 42 offset and running 225 with a pro kit i have rubbed twice now... if you are going to run 225 then it may work but if you are gonig to run wider tires you need a bigger offset...
