Hey everyone - before I pull the trigger on some wheels I wanted a group opinion on fitment for my 2. I'm ordering a set of 16x7 wheels that come with an offset of +37 from Tire Rack. Technically, they are a fitment for the 95 Miata. As far as I can tell from everything I've seen here, these should fit just fine - but I might be wrong. Can any of you with similar fitments, or knowledge of similar fitments chime in if you know this will work? The cost is just high enough that I want to make sure it's right the first time. Thanks in advance!(whistle)
BTW - I'm riding on stock suspension now, and will be lowering with H&R springs, or the CorkSport springs/shocks combo when it releases this fall. Either way I won't be going any lower than that.
