someone is selling 15in steel rims that i want to use for the winter, they fit the p5? anyone use them last winter? there 5x114 mm bolt pattern which I believe is correct as well.. Thanks..!
Yea.. But i wanted to know if they will fit my p5.. Im like 90% sure i have seen p5 with 15in steel rims.. and thats the same bolt pattern, so i dont know why it would not fit.,??
5x114.3 is, indeed, the bolt pattern. If they arent' off an MP3, just check the hub bore to make sure it's right (I can't remember what the bore is on the P5). Backspacing shouldn't be an issue.
