mikeeeee said:how did you guys boost past 10 psi?
i thought that there was a cut at 10 till we get bigger maf or am i mistaken?
I noticed he has joe p's FCD which allows him to run 10+ psi of boost without fuel cut.
the reaction times are actually slow if I can see them but the times are excellent. looks like one redlight but the rest are 1 sec +
Db1707 said:I noticed he has joe p's FCD which allows him to run 10+ psi of boost without fuel cut.
unwrittenLaw said:Also, the fuel cut is not psi-based, its based on airflow...depending on the weather you could run higher than 10 w/o hitting fuel cut. If its cooler out, the air is denser, so you could hit fuel cut at less than 10, if its warmer..you could go to 11-12, maybe more w/o hitting fuel cut...
ChesteR said:Good reaction times...hahahhaahha.
Maybe if he was blind.
something in the .600 range on an amateur tree would be good.![]()
