10 disc and sirius?
speedfrk
I have a 10 disc that works if I diconnect my sirius and plug it in directly but if I try to hook it up to the extra port on the sirius box no luck?
Is there a trick I dont know about?
Have you tried reversing the order? Putting the changer in-line in front of the Sirius tuner?
hmmm... Well, I don't have a changer installed, but I did an extra line-in to my system, and originally we tried the $20 line-in adapter, but because of the Sirius tuner box it didn't work and I had to get a more complicated line-in adapter. I don't know if this what your situation calls for though.
I would call Kenwood support or Sirius Support, that's what we did when it didn't work with the line-in adapter. And that's how we found out I needed the more expensive box. Unfortunately it isn't on or is very difficult to find on the kenwood website, and I don't have the model number handy.
speedfrk said:
You cant put the changer first . The sirius has a slave port for the changer to work from .
^^ try this
it might not be the same unit but try to get an example, hope the pic helps :)
changer
How did you find out what adapter you needed? do you have a Phone #?
Ok no Problem I figured it out . The changers have a switch right inside the loading cover that say o-n just switch the position to n and all is good.
