07 cx9 awd right rear abs sensor plug location???
hkp
cx-9
Changed my hub and of course the abs sensor s*** the bed, anybody know the exact location of the plug and what needs to be removed to access it? Thanks dudes
If you pop off the cup holder in the third row seating area, under the big harness theres a 2 pin connector with grey and white wires, thats the clip for the passenger side abs sensor, if you want it out you are going to have to remove the rear seat, remove the lower seat belt bolt, and one other ten mil bolt, unclip the lower door sill, then you can slide your hand between the cover and the body and tear the tape thats holding the wire in the middle, then pull it from the outside and it will come out. you can rip all the clips on the outside because the new sensor comes with clips. i got my sensor for 130 after over night shipping. best of luck to ya.
Beats the s*** out of paying someone to change out a 2 wire sensor that's held in with one bolt.
