05 mazda 3 tires help please!!!!
Can you post your wheel specs? 18" x ___ " (width), offset ___ mm
What tire size are you running now? Where is the rubbing?
It is a konig trouble 18x8 offset 40 there are 235/40/18 on now. I haven't. Put them on yet because the tires are really bad but I have been told that the tires are too big about 2 inches and it will rub. Are 215/40/18 fine? I don't wanna waste my money on bad tires and I want my car to look nice.
With an 8" width you'd really be better off (wheel-tire matching wise) with a 225 width, but 215/45-18 would probably be a better size if you want to avoid having to roll fenders. I'd feel pretty comfortable with 215/45-18. 215/40-18 won't give you much protection for road imperfections and such.
Oh ok, cool. Did you end up with 215/45-18? No rubbing?
None at all man now I wanna drop my car about 1.5 inches... do u know anything about that oh and correction the tire size is 215/40/18
Eibach Pro-Kit should drop you about that amount. Also - browse through this section for other recommendations:
http://www.mazdas247.com/forum/forumdisplay.php?f=321
I got 225/40/18 w/ a 1.3" drop and I only rub when turning with a bumpy road
doesn't mean anything without posting your wheel width + offset
