First off, I did search lol. Nothing bugs me more than people who don't. So I hope I didn't miss the simple answer somewhere, I swear I looked first!
So my 03 automatic P5 died while I was driving today. No bangs/booms or any catastrophic noises. Just died. Will not restart. Cranks all day long, but will not catch, doesn't even try.
Symptoms:
INJ/FIP fuse (30a pink one) in under hood fusebox is blown. Replaced it, and it blew again as soon as I turned the key back on to the IGN position.
Temp needle pins itself when I turn the key on to IGN position. I had only been driving for 5 minutes when it died this am, temperature hadn't even come up to normal, let alone overheating. The needle was acting normal until then. Car has been sitting for 5 hours now, I assure you it's not overheating. Temp needle still goes straight to maxed out when I turn the key on to IGN.
Code reader/scanner won't work. It says it can't connect to the system/vehicle. Tested it on a Dodge and a Lexus (just what I have handy) and it works fine on both of them, so it's not the code reader. And now I have to do the O2 sensors in my sister's Lexus, too lol.
So hit me with your ideas everyone. Obviously, the reason it won't start is a fuel problem. But why does the injector fuse keep cooking? Could this be the fuel pump relay? I'm open to suggestions, so let them rip!
Symptoms:
